When Signal K is installed on the Cerbo GX do the following plugins need to be installed in Signal K?
- signalk-venus-plugin
- signalk-ruuvitag-plugin
- signalk-wilhelmsk-plugin
Thanks!
Thanks!
Not by default. However, you can make use of Node-RED (requires using the in Signal K embedded Node-RED!) and then use the signalk-send-nmea2000 node to send your own messages.
signalk-venus-plugin comes pre-installed.
The other two aren't, but they're not necessary either. RuuviTag connected to the Cerbo GX via Bluetooth automatically makes all data available on Signal K. The WilhelmSK plugin is only required if you want to save custom gauges on the server for use on other devices.
49 People are following this question.
