Is there an alternative method to reset/reboot Cerbo remotely when display is frozen or stuck?
If you have enabled it, you can ssh to it. This is not on by default however.
Alternatively, if reboot on communications loss is enabled, you could try disable it's wifi from your wifi access point.
When revering to SSH, are you talking about the ‘remote support functionality’. If so, then Yes it is enabled, but I still cant access via this route. I can login/connect to Cerbo remotely (I am 6 hours away from site) via VRM, but can’t shuffle through display or get to reboot. I have never used the ssh method, and not getting it to work either.
41 People are following this question.
