Deon avatar image
Deon asked
EasySolar 5000/48 with 250/100 MPPT - VE.Bus voltage increases when MPPT start limiting the input power
Installation is an EasySolar 5000/48 with the MPPT upgraded to a SmartSolar 250/100, charging 2 x US3000A Pylontech batteries. Solar panels are 4 strings of 4 panels each (48V, 420Watt) giving Wp of ~6400W.
The Ve.Bus voltage increases when systems starts limiting the Solar input power to ~ 4500-5000W (the limiting level is ambient temperature dependent)
Is this a bug?
If not, what is the reason the bus voltage would go higher only while limiting is active?
VE.Busbattery system voltage
What is VE.Bus?
