corby avatar image
corby asked
Can I use a shorter cable to connect the BMV screen to the shunt?
I am installing the BMV-712 very near the shunt (using bluetooth rather than panel for most functions).
The supplied UTP cable is much too long for my install. I would like to make my own cable.
The original cable appears to be CAT 5E ethernet cable with RJ12 connector.
Is it necessary to use CAT 5E cable or will lower grade 6 conductor cable be acceptable. Planning to use 1 to 2 feet.
Does the cable need to support high speed data transmission?
wiring
corby avatar image corby commented ·
Amazon sells RJ12 cables with straight through connection having flat 6 conductor cable. Not a high speed cable.
https://www.amazon.com/Pack-Feet-Cable-Modular-Black/dp/B01M0GCXA4
Would this cable work with BMV-712?
boekel avatar image
boekel answered ·
Yes you can use any 6 wire RJ12 'patch' (straigh) cable
I usually order a bunch, cheaper than making them myself.
Thanks much @Boekel .
digitmag avatar image
digitmag answered ·
Hi @corby
It is a point-to-point serial connection, not an ethernet one.
You could check the provided cable with a continuity test to check it is a straight through pin-to-pin and buy or make a similar one
I know the cable is straight through. Can a flat, non twisted cable handle whatever data speed the Victron monitor is using. ? After all they ship it with Cat 5 for some reason. I have never seen cat 5 used with RJ14 other than here
