Hi!
I have run out of free temperature inputs on my cerbo. Now I realized that i haven't used the temp input on my multiplus.
Does the multiplus send the temperature over ve.bus even if the unit is off? (Off as in soft-off)
Hi!
[Edited] Yes the temperature from the multiplus is seen on the VRM
See here.
Not the same way the ones for the Cerbo are displayed. Sorry Friday brain...
My apologies.
The answer I gave was not clear. The answer is yes it does send its information send to the VRM to a widget in the advanced page, not the same as the Cerbo sends to the dashboard.
If the inverter switch is off, data is not sent.
There was a time that the temperature sensor connected to MP-II was visible on the VRM dashboard.
To remove it from VRM dashboard was a concision decision on the VRM team part.
I disagree with that decision, but what I can do about it.
29 People are following this question.
