campdaily avatar image
campdaily asked
Multiples Compact not enough be bus ports.
My Multiples only has two ve bus ports. I need to connect a CCGX, a DMC & a ve bus BMS. Any ideas how?
multiplus ve.bus
johanndo avatar image johanndo commented ·
Ve.Bus is a serial bus architecture, all wires are parallel. You can get a RJ45 splitter if you cannot daisy chain the bus through all devices.
Kevin Windrem avatar image
Kevin Windrem answered ·
Loop from one to the next, to the next. If a device only has one port, put it at the end of the chain.
Just read the manual...
The DMC is connected to the VE.Bus BMS there is an extra VE:Bus port for that.
