I'm occasionally getting MPPT state 245. I can't find it defined anywhere in the doco. Does anyone know?
Hey! I do not have an official answer for you. But I'm seeing this too and I have noticed that this only happens under the following circumstances:
So I am guessing this is kind of a "pre-start" or "calibrating" state right after the panels supply enough energy (threshold) for the charger to start but before actual charging begins.
For completeness' sake the full list:
State | Meaning |
0 | Off |
2 | Fault |
3 | Bulk |
4 | Absorption |
5 | Float |
6 | Storage |
7 | Equalize |
245 | Pre-Charge / Calibrating? |
252 | ESS |
As per the documentation of the ve.direct hex protocol "Device state values (register 0x0201)" state 245 means "The device is about to start (signal to external control)".
68 People are following this question.
