What is the maximum size SD Card for the Cerbo GX? Should it be formatted to FAT32 prior to use? Can it be configured for data logging at the same time that data is being logged to the VRM Portal?
Hi @Phil
The answer can be found here: Datalogging to VRM - Storage device requirements
42 People are following this question.
