Hi everybody.
I am using Multiplus II with GX but I want to have touch display on wall to easy monitoring of state. It is possible to connect raspberry Pi with Venus OS to Multiplus II GX only for HDMI output? Thanks for answer.
Hi everybody.
No, as this would put 2 GX (control) devices on the same system. If you want the Pi and Touch display, then the internal GX would need to be disconnected. (BTW, does any one know where I can get 5 Pi3 B+'s from?)
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
79 People are following this question.
