Can you connect the touchscreen GX Touch 50/70 to the Multiplus II GX?
The datasheet on GX Touch says you connect it to Cerbo GX, but I could not find any info
about connecting it to Multiplus II GX (which has 1 usb port)
There is no HDMI port at the MultiPlus GX, so you can't connect the GX Touch to it.
59 People are following this question.
