Multiplus 24/3000 label show AC Out 1 = 21 Amps
The documentation along with posts from others says it's about 70 Amps.
Please clarify...thanks.
That's the inverter power (2400W / 115V = 20,8A)
70A is the transfer relay capacity + inverter power (Power Assist).
30 People are following this question.
Victron Multiplus Ground Issue?
Can a GX access information if 2 Multiplus are on the same bus, but driving two separate AC loads
N/####/system/0/Connected Not accurate / changing & N/####/system/0/Ac/Alarms/GridLost
measuring separate AC power usage from inverter via VRM
Can setting low temp cutoff in BMV-712 stop AC converter charging?
