I am currently using the Color Control Gx with 2 Mppt 250/100 smartsolar i want to add a another Mppt 250/100 smartsolar can i use a usb to ve direct as the Color Control only have 2 Ve Directs Will it work or cause issue ?
As per the spec sheet:
When more than two VE.Direct products must be connected, USB can be used
47 People are following this question.
