alnavasa avatar image
alnavasa asked
Wet lead battery settings for MPPT 100/50
What are the best settings or the best preset, for a 3 x 120ah (800A) batteries bank. The batteries are wet lead with the ability to top up each of the six cells with de-mineralised water.
All the settings I can see are for either AGM or Gel, or Lithium...
I don’t really want to be messing or testing settings and editing the presets and have a look... I would like to know if one of the presets fits, and if none does, then make one.
MPPT Controllersbattery charging
wkirby avatar image
wkirby answered ·
It's best to consult your batteries' documentation to set the correct parameters for them.
There can be some variance between manufacturers / models.
Also pay close attention to the Equalisation Voltage settings too.
Sorry, we can't provide a definite answer without knowing any ,ore information.
Murray van Graan avatar image
Murray van Graan answered ·
Best would be to set it up using VictronConnect, set the battery type to user defined and then set the charge parameters according to the battery manufacturers specifications
neoneddy avatar image
neoneddy answered ·
The AGM profile will do you ok.
But you can do 14.5 to 15 v on bulk / absorb on wet cells, just watch the water.
Float around 13.6
alnavasa answered ·
From the manufacturer I got no answer, well I can't even contact any information or contact email (Movilbat)
Any standard settings for 140 amps wet lead with the ability to top up each of the six cells with de-mineralised water?
JohnC avatar image
JohnC answered ·
I use flooded daily cyclers, and the Victron defaults are perfect. 14.4V abs and 13.8V float. There'll be a preset 'flooded' one to pick out if you've changed it.
A maintenance charge might only need to see 13.2V every day. So depends what you're doing with them. Temp compensation is fine/best left on, so you'll see deviations from those V's in practice.
alnavasa avatar image alnavasa commented ·
Cant find any preset as "flooded daily cyclers"
Those values match with gel batteries preset.
klim8skeptic avatar image klim8skeptic ♦ alnavasa commented ·
According to the manual https://www.victronenergy.com/upload/documents/Manual-BlueSolar-charge-controller-MPPT-100-30---100-50-EN-NL-FR-DE-ES-SE.pdf
page 10, preset 0, 1, 2, and 3 are suitable for equalization for flooded cell batteries.
Pick the preset that matches your batteries recommended charging voltages.
