Hi guys!
I do not have any equipment installed yet, but I am having a look at a configuration with a Cerbo GX (battery bank + ongrid + solar pannels).
The VRM Portal could be something great, but I am not found of cloud services at all. I want the data to stay within my network.
I want to be able to access to a part of my LAN through a VPN connection, where I could then reach eventually the Remote Console through a web browser, if this is possible.
So far I understood, the status on the installation will just be available from the VRM Portal. Using Grafana would be the alternative solution. But here, this would require some cloud account, unless I would go for some "enterprise" feature to have a local instance.
With the principle of my data is my data, and I do not want to share it at all. Governments and Big Tech should have hands off my installation. Security is tightened to the max. No use of Big Tech at all.
How would you see the whole solution?
Thank you.
