davidv avatar image
davidv asked
Ev charging station automatique mode
Hello
I like charge my car with automatique mode.
I connect car with ev charging station, i start automatique mode, after this a car bloque process charge.
With manuel mode no problème it's ok.
My système is an ESS 3 phases
CCGX version: 2.89
Ev-charging station version: 1.22
Véhicule: Audi Q4 E-TRON
Can you help me please ?
ev charging station
davidv avatar image
davidv answered ·
Does EV Charging station use IEC 15118.2 protocol?
modian avatar image
modian answered ·
If you are not feeding into the grid the EVCS could actually not used in automatic mode. I have the same issue with my ESS and EVCS. As far as I understood its will come (hopefully) in a future release
davidv avatar image
davidv answered ·
Hello Community,
I installed firmware V1.26
This improves the automatic mode of the charging station.
Thank's Victron staff
For a future, It is possible to add a new setting: Max power storage batteries?
Have a good day.
eleusis avatar image
eleusis answered ·
Resurrecting old thread, but is it still the case that automatic mode only works when back feeding to grid and ess mode?
greendovefarms avatar image
greendovefarms answered ·
I dont have any problems running in automatic mode and system is totally off grid
Maybe I have different settings loaded into the EV charger
freequader avatar image
freequader answered ·
Bonjour,
A l'inverse j'aimerais faire fonctionner la EV charging sans Batterie, juste le surplus solaire. Mais malheureusement je ne trouve pas le paramètrage. et j'ai toujours SOC low
