truckingpilot avatar image
truckingpilot asked
is there a detailed diagram of the circuit to connect t a bilge alarm to the Cerbo GX?
cerbo gx
mike4nl avatar image
mike4nl answered ·
@truckingpilot Please can you describe a bit better what you wish to do?
- Bilge pump 24V?
- What will you connect to the Cerbo GX? Which wire or which function?
- The Cerbo has a 5V input.
I can help in so far when you give me more information. I have made more then one drawings in Visio or Paint-Dot-Net for off-shore things.
May i ask from which country you are?
Addition: has your Bilge Pump System a Bluetooth connection?
johanndo avatar image
johanndo answered ·
you need a voltage divider with 2 resistors to get in the proper range the cerbo can monitor on the digital inputs. Alternatively you can add an extra float switch dedicated to the cerbo between digital input and ground.
