I get the following error when updating the firmware. what could be wrong. I am using the MK3 usb. My Multiplus continuously stays in Bulk that's why I want to try the update
Battery charging problem has been solved.
I just saw in the VE config that the charging current was at 0 Amps.
As a result, the multiplus remained in bulk and only gave 1.1A on the ve bus monitor.
Could the charging current of the Multi have been set to 0 amps because I was testing with DVCC in the cerbo GX?
Is a slightly older unit.
victron connect I can't use. get the message to update from 209 to 4xx first.
As far as I know the DVCC setting does not write settings to the inverters. So may have been a typo the last time you did settings?
Only input current limit can be overuled by remote if checked.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
31 People are following this question.
