chrispendl avatar image
chrispendl asked
Quattro Assistant Question
I currently have two Quattros installed on a boat (120V system) with a 9kW generator. When I set the incoming amperage limit, the system doesn't seem smart enough to regulate how much power is being used to charge the batteries vs how much is used to power the AC loads.
Is there a way for the Quattros and Cerbo be smart enough to look at the total power available from the generator and route appropriately between AC loads and battery charging?
Thanks!
powerassist
Kevin Windrem avatar image
Kevin Windrem answered ·
The current limit is supposed to act as you describe.
If this is a parallel system, then the current limit you set is PER UNIT, not total.
