The EasySolar goes to Sustain Mode. At 4:00 in the morning a bigger Load switches on (washing machine). The reason for Sustain Mode is the Battery Voltage? Best regards Thomas
Sustain, which Victron call absorption, is the fixed voltage part of a three or four phase charge cycle. Once voltage hits 14.4, AGM batteries are about 80% charged. Constant voltage completes the charge and current drops as it completes. Then the battery is held at a lower voltage, called float - charged, ready for action.
In ESS, sustain is triggered when the battery dips beneath the dynamic cutoff voltages.
What batteries are these?
How have your ESS cutoff voltages been set?
Have a read of dynamic cut-off in the ESS guide.
That large load may be setting it off.
I use the Victron 12,8V Lithium SuperPack with internal BMS. The Sustain Voltage in the ESS Wizard is set to 12,5 Volt. The "Entladeschlussspannung" (sorry in german) is 10 Volt. Do I have to adjust the Sustain Voltage in ESS Wizard to an other value than 12,5 V ??
There is also Peukert law in play
https://en.wikipedia.org/wiki/Peukert%27s_law
if you add your capacity with parallel batteries, discharge rate per battery will decrease and you voltage drops slower, hence you won’t trigget the sustain that easily.
37 People are following this question.
