Luit Jan avatar image
Luit Jan asked
Alarm on tank level
Hi Experts,
My Cerbo is connected to 3 tanks and gives the level in percentages. Is it possible to get some kind of Alarm when the level reaches a defined percentage?
For example: percentage reaches 80%: Alarm in mail or text message?
Thanks for your reply,
Luit Jan
tank monitor
Kevin Windrem avatar image
Kevin Windrem answered ·
There are no alarms, however you might be able to use the tank pump mechanism which closes a relay when a specific tank reaches a specific level.
Tank level alarms would make a good addition for RVs.
Luit Jan avatar image Luit Jan commented ·
Correct! But then I lose the Gen set relay which I also use.
nickdb avatar image
nickdb answered ·
Would the node red tank sensor node not help you construct one in a flow?
If it is able to read that value from the sensor it is easy enough to build a flow.
Not having a tank sensor, I can't check but the docs state level(%) is available if supported.
I think Victron should add this functionality to the Cerbo. In my view this should be very easy. As the Cerbo is aware of the percentages, has a mail address, even a text message should be possible.....
pwfarnell avatar image
pwfarnell answered ·
If you want to be emailed an alarm then you could set the alarms up on VRM assuming you have connectivity, that is what I have done.
