M. K. avatar image
M. K. asked
MPPT 450 200 RS BYD High Voltage Alarm
Dear Community,
I have an issue with ESS system, the system is DC coupled solar system with the following:
  • MultiPlus II 48/8000/110-100
  • MPPT RS 450 200
  • Cerbo GX + Touch
  • BYD BMU
  • 8 x 5kWh LV Flex Lite
  • normal protections with by pass change-over switch
So, I programmed the system in ESS mode with all parameters checked... when the batteries are full I am receiving an alarm on the Cerbo "BYD Premium LV battery High Voltage" I guess the BYD BMU is sending this alarm to the cerbo.
Everything is working fine. I can see the alarm when the battery is full. So, maybe there is a delay in the MPPT or the BYD BMU parameters have to be adjusted. if you have the solution then please share it.
Thank you in advance,
BYDbattery system voltage
Victron BYD battery compatibility guide
