Sarvesh Gupta avatar image
Log data problem
Hi
We have installed Multiplus 48/5000 with 6kW PV panel and 10 kWh Storage. When we access the VRM portal we found there are two types of data available:
1. Download.CSV
2. Download kWh .CSV
On downloading both the sheets and comparing the data we have found
> the PV Generation going to battery
> and Energy stored in battery going to customer
is having large gap.
This is showing that batteries installed have got poor efficiency, which actually is not the case. Using the same sheet (Sr.No.1-Download.CSV) we have calculated the Round trip efficiency of the battery and it is coming out to be 93%. Can you please tell us the reason why these two sheets are showing different efficiencies?
For reference i am attaching both the sheets with calculations.Problem.zip
Regards
Sarvesh Gupta
MPPT - Solar Charge ControllerMultiplus-II
problem.zip (4.0 MiB)
Hi Stewart
Could you solve the issue?
It is long pending.
Share
Hi Stewart VRM is running on the latest firmware version. Please advise further.
2 comments Share
Hi Sarvesh,
Anytime there is any issue of accuracy with VRM, the first thing to do is to be sure that all the firmware on all the connected devices is the current latest version.
Could you please confirm that you are running the current firmware on all connected equipment?
1 comment Share
Hi stewart,
I have been waiting for your revert on the problem for a long time now.
Also Battery SOC is not coming in the log data, is there any specific reason for that?
We want to record the battery soc also in the data, so that clear under standing can be made about whether my battery charging or discharging.
Expecting a speedy revert on the same.
