pyves avatar image
pyves asked
multiplus 12/1200/50 charger light flashing
Hi, I used VE Configure to configure my Multiplus 12/1200/50 and when I send the modification to it, the charger light started to flash. And now, I even cannot to connect back to it, even when using Victron connect. Any idea why ? Before doing the VE Configure, the multiplus was working fine, but wanted to select the right battery model (lithium).
Thanks for your help
multiplus ve.bus
Paul B avatar image
Paul B answered ·
install the victron toolkit app. and then look at what the flashing led lights mean.
then this will give you a idea as to what to do, or report back here with a screen capture of the error
jbroo avatar image
jbroo answered ·
I have the same problem after changing the inverter dipswitches to the Lithium battery setting. I've checked the app above and there's no info for this model at all. Did OP resolve this issue, and how?
