adrianop avatar image
adrianop asked
Connecting Cerbo GX to EasySolar
Can anyone clarify how to connect a Cerbo GX to an EasySolar?
Using a VE direct cable, do you connect a VE Direct port to the integrated MPPT?
Or, do you connect using a VE.Can port to the integrated MPPT?
Or something else??
Many thanks in anticipation......
EasySolar All-in-One
Which EasySolar do you have exactly?
https://www.victronenergy.com/inverter-charger-mppt/easysolar
https://www.victronenergy.com/inverter-charger-mppt/easysolar-ii-gx
The old 3kVA/5kVA and the new EasySolar-II already have a GX device build-in, there is no need for a Cerbo GX.
adrianop answered ·
Hello Matthias,
I have the EasySolar 24v,1600
https://www.victronenergy.com/upload/documents/Datasheet-EasySolar-1600VA-EN.pdf
I don't think there is a built-in Cerbo GX? I may be wrong - there are so many model types.
