rb-wingman avatar image
rb-wingman asked
Can I Use Multiplus and Blue Smart IP22 12-Volt 30 amp simultaneously while on shore power?
Newbie. I have a Multiplus 3000/50/120 and a Blue Smart IP22 30 amp charger. Can I charge my 400ah battery bank with both simultaneously? If yes, best place to hook up Smart charger?
Thanks much!
Alexandra avatar image
Alexandra answered ·
@RB Wingman
Yes if your battery bank is able to take the conbined charging amps of both the inverter and the second charger of you are planning on using them at the same time.
And where you connect it depends on if you have a shunt or not.
rb-wingman answered ·
@Alexandra - thanks. I do have a victron smart shunt. How does that impact where I connect smart charger? Thanks.
I am assuming your inverter is also a 12v. And you are not using the mutliplus to run the smart charger but shore power (you may laugh I have seen it - add face slap emoji here)
Connect the negative to the shunt on the charger/loads side.
For the positive to either the bus bar for positive or the battery terminal (this depends on how stacked it is already though. If you do stack add it on top of the inverter lug not under.
And dont forget to fuse it
