Schunk avatar image
Schunk asked
Cerbo offline - even no connection via bluetooth
System: MPII ESS with Cerbo and local screen display and 2 MPPT´s
During vacation I was unable to find system data via VRM; lock in possible but no longer actual data available.
Back home same situation via PC, than I tried to get local access via bluetooth, no connection possible for Cerbo. MPPTs are fine.
Im not the detail speci and newcomer in this community; Is there any chance for help?
Can add screen shot, but no idear how to use here.
KR
Eckart
cerbo gx
Alexandra avatar image
Alexandra answered ·
@Schunk
You will probably have to pull the power plug out and wait a few minutes then plug it back in.
Not something I would normally recommend.
Then when it has finished the reboot, you can set it up to reboot when there is no contact automatically
Schunk avatar image
Schunk answered ·
Hi Alexandra,
many thanks for your assistance.
Wean while I followed up a similar way to solve the problem.
- first I restarted MPII incl. battery whithout success; because MPPT feed the 48V busbars .
- didn´t rermeber that Cerbo was connected via pluc, therefore I took out the fuse
- reboot was autimatic
Best regards
Eckart
@Schunk
So now on your device go to
Settings - vrm online portal - reboot on no contact enable that.
Then the system can sort out its own connection.
