chrisu avatar image
chrisu asked
Multiplus-II 5000 GX no wifi reconnect
Hi there,
I have an MP II GX which is connected via Wifi to local my Internet Router (Fritz box). Ethernet is plugged out.
IP is manual, everything works fine.
But when I switch off the Wifi Router and reboot, the Multiplus GX does not reconnect to the router. I have to reboot the MP and then it connects to it.
Is this an error by design?
I don't want to use the ethernet connection because I want to connect from MP to the EM24 without having an ethernet switch between to minimize hardware faults.
Multiplus-IIwifi
nickdb avatar image
nickdb answered ·
Is your GX up to date with firmware? You can also set the GX to auto restart itself if there has been no comms for a few minutes. This sometimes happens but on newer versions less so, unless there is weak signal.
chrisu avatar image chrisu commented ·
I have the latest FW installed.
Where Do i configure this reboot Feature?
Signal is 80% and 2.4ghz, so this should be pretty ok.
nickdb avatar image
nickdb answered ·
Settings -> VRM online portal
thank you, I'll try!
it's working, thanks for this solution!
