subzero avatar image
subzero asked
Multiplus Compact 12/2000 fault
Please help me figure out what went bad on a Multiplus Compact 12/2000. The inverter works as expected. However, the charger does not come on and the unit does not connect to shore power. I have tried multiple sources for the shore power and check the wiring. The unit worked previously without any issues.
When I plug in shore power, the DMC flashes the blue "mains" light and I can hear a relay briefly engage then disengage. It does this three times, then nothing.
On Victron Connect, I see AC voltage available at 60hz (at the house it showed 120V, this photo was when it was plugged into a generator where is shows 128V)
I have checked and double checked the wiring, nothing has changed. I updated firmware and checked the setting and even tried a few different configurations, but nothing works. It just clicks some relay, then shows fault.
As I mentioned, it worked before. I don't know what changed or why is won't work now.
ac
Mike Dorsett avatar image
Mike Dorsett answered ·
I had a similar problem with a compact 24/1600, this turned out to be some burnt out relays and corrosion on the AC board.
