tom4x avatar image
tom4x asked
Does activating Remote On/Off disable the configuration ability via VE.Direct?
This may be a silly question, but I haven't found a definite answer in the documentation.
I know that I can't use Remote on/off and VE.Direct at the same time, that's clear. Can I safely activate the "Remote on/off" function on the VE.Direct port of the SmartSolar 150/35 without losing the ability to use VE.Direct for configuration?
I can't use Bluetooth on this device, so I want to be sure not loosing access to the device.
Thanks in advance.
MPPT ControllersVE.Direct
wkirby avatar image
wkirby answered ·
There are no silly questions around here.
Yes, the VE.Direct functionality still works even when the Rx port function is set to Remote On/Off.
