fabians avatar image
fabians asked
SmartSolar 75/15 - AES only if solar present?
I got an SmartSolar 75/15 and a foldable solar panel only connected sometimes. The SmarSolar load output is configured with AES and connected to my Fridge S+ signal. So if I have excess Power it will switch on the load and the fridge will use 12V instead of Gas.
My problem is the AES logic in the SmartSolar also switches on if the condition are met due to other reason (230V battery charger or B2B charger from car generator) but no solar power is present.
Is it possible to have an additional AES settings for minimal Solar power for AES to switch on, additional to the existing config. This should also solve the issue that the AES might switch on late in the evening when there is not enough power for the fridge present to prevent drawing too much from the battery.
Thanks,
Fabian
aes
