Is it possible to change the name of a BlueSolar controller using the VE.Direct Protocol? I can change the name using the VictronConnect app but not seeing how I would do that with VE.Direct HEX.
Hi @palu3492
It depends a bit on the product whether the name can be set using VE.Direct hex or not. When the name is editable in VictronConnect when it is connected via a VE.Direct cable, it can be set via VE.Direct hex. For the BlueSolars and SmartSolars without a VE.Can connection this is not the case.
For the products where it can be set (BMV712, SmartShunt, SmartSolar with VE.Can connection, Phoenix Smart Charger), the vreg to use is 0x010C with a maximum of 20 data bytes. So the command would something like this:
:80C010048454C4C4F20574F524C442103
Kind regards,
Thiemo van Engelen
28 People are following this question.
