mikeh avatar image
mikeh asked
MK3 USB adaptor connection to Android 7 phone
I am trying to connect a Sony Z3 phone running Android 7.1.1 to a 12/3000 Multiplus inverter using VictronConnect v5.61 with a MK3 USB adapter. VictronConnect starts to search for devices but fails to see the inverter. It finds the BMV700 meter over bluetooth ok.
I know the MK3 USB adapter works as I have used it to connect a Windows 10 laptop using Victron Configure.
Have I missed something
This adapter is left plugged into the inverter all the time - is this OK to do or should it be removed after use.
MK3
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @MikeH
I assume that you are using a proper USB OTG cable to connect the MK3 to the phone? What happens when you insert a USB stick into the OTG cable? Does the phone recognize the stick?
I also found some information online that says that it is necessary to let Android look USB devices via Settings > Device connection > USB Connectivity > Detect USB device .
Kind regards,
Thiemo van Engelen
