sesshoumaru avatar image
sesshoumaru asked
Unexpected discharge, float not reached
Hi
I am observing the systemn how here and there and I noticed that the "float" state is never reached. It seems to move between "charging", "absorption" and then "discharge". Below you see that excess energy is feed to the grid, but still the battery discharges - if not much, but it does. Is that some configuation issue? I would have expected the battery (pylontech US2000C - 8 units) to float.
MultiPlus Quattro Inverter ChargerESSPylontech
seb71 avatar image
seb71 answered ·
100W drawn from a 19kWh battery is nothing.
Who made the settings? How long is the Absorption time set?
sesshoumaru avatar image sesshoumaru commented ·
Where can I find the Absorption time?
Has been configured by the Victron Distributor I guess as I did not change the system settings.
seb71 avatar image seb71 sesshoumaru commented ·
When using ESS, the charging settings are those programmed in the inverter.
