gsking avatar image
gsking asked
VE Smart voltages not matching
I figured out I could use VE smart to tell my MPPT what the true voltage at the battery was.
Except it’s not so smart. The mppt has gone into float at 3.6V but the battery is still at 3.45 as reported by the smart bus.
Isn’t this exactly what smart networking is supposed to correct? The mppt should be running at higher voltage knowing the battery isn’t full.
MPPT ControllersVE.Smart Network
Alexandra avatar image
Alexandra answered ·
@Gsking
It will go into float only after it has reached absorption.
What do you have your rebulk offset set to? Maybe it has been drawn down enough again and bulk charge stage just has not been triggered.
gsking avatar image gsking commented ·
I think the problem was that Ve smart does not always connect. Wherever the logo pops up, the connection is made and it works properly. When the logo isn’t shown, it means the connection isn’t active so the mppt has to rely on charging voltage not battery voltage.
It seems to be working now.
MPPT Product Page
MPPT Error codes
VE.Smart Networking Manual
