denzel avatar image
denzel asked
How to configure ESS if inverters are in Parallel ?
Hi Guys,
I finally got my 2 Multiplus units in parallel . But how do i add assistant etc as you cant program these now from the veconfig as they in parallel ?
ESSmultiplus in parallel
wkirby avatar image
wkirby answered ·
You need to connect to each MultiPlus via VE.Bus System Configurator which will then lead you to VE.Configure for that device.
Inside VE.Bus configurator, you can right-click a device and then choose "VEConfigure Multi".
