I am looking for a simple solution to run 2 KUS tank monitors with the Raspberry Pi Venus OS.
What is everyone else using?
Thanks!
Thanks!
Hydrostatic tanksensor 0-1m and I2C interface with a ADS1115
You could use them probably with a Victron USB tank interface too (current loop 4...20mA, 12V), very precise, +/- 1 liter on a 600l fresh water tank
Is the current loop always 4-20 or does it need to be adjusted.
I have the tank 140 connected to my lpg tank and water tank.
GX tank 140 does not work with resistive sensors, only Voltage and current will work.
okay. This is the water sender I have
KAOLALI Fuel Gas Sender Stainless Steel Fuel Sending Unit 200MM Marine Boat Water Level Gauge Sensor 5 Hole fit Fuel Water Gauge 0~190ohm https://amzn.eu/hs23ncw what type is this?
https://www.lpgshop.co.uk/4-hole-livello-level-sender-sensor-0-95-ohm/ and this lpg sensor
31 People are following this question.
