sloopjohnb avatar image
sloopjohnb asked
Victron Energy Cyrix-i 24/48-Volt 400 amp Intelligent Battery Combiner with LiFEPO4 BMS batteries
Will the combiner work with LiFePO4 batteries with a BMS built in? The input to the combiner will be a 300 amp dedicated alternator which chargers a 100 AH 12DC AGM starter battery. When the AGM is charged (voltage high enough) will the battery combiner start charging the LiFePO4's? Will it stop when the BMS on the LiFePO4 cuts off the connection? Is that one of the design features of the product? It does look like it will, but there is no specific mention of LiFePO4's in the combiner literature. Thanks ahead of time!
Cyrix Battery Combiner
