Anyone got Shelly EM to work with Venus OS to se Grid watt usage?
Like this : https://community.victronenergy.com/questions/125793/shelly-3em-smartmeter-with-venusos-cerbo-gx.html
/Mattias
/Mattias
I modified the code from the 3EM for the Shelly EM here
https://github.com/vincegod/dbus-shelly-em-smartmeter
I ran is for a month but swapped to a hardware current sensor extended over 25M CAT6.
Vince
Yeah, there's this one
https://community.victronenergy.com/questions/127339/shelly-1pm-as-pv-inverter-in-venusos.html
I've modded that one for the Plus 1PM too if you need it.
Hi . But that is for Shelly 1 PM . I ment a Shelly EM with a clamp (like the EM3) and I want it showed as AC Input not Inverter... Ā“Could you make a script for that? /Mattias
@Vincegod . Ok great news! I have tried to copy/paste
wget https://github.com/vincegod/dbus-shelly-em-smartmeter/archive/refs/heads/main.zip
unzip main.zip "dbus-shelly-em-smartmeter-main/*" -d /data
mv /data/dbus-shelly-em-smartmeter-main /data/dbus-shelly-em-smartmeter
chmod a+x /data/dbus-shelly-em-smartmeter/install.sh
rm main.zip
But I get this
Must say Im not an PI expert!!!! :)
/Mattias
Leider erscheint der Shelly EM nicht in meinem HauptmenĆ¼ vom Victron. Dort ist nur der per Modbus verbundene SMA Wechselrichter.
Im UntermenĆ¼ erscheint der Shelly jedoch.
Jemand eine Idee?
Hier die Config
Und der komplette Aufbau
You want to measure between Growatt and MPII?
Have a look at this YT Video at 21:30
https://www.youtube.com/watch?v=ki9uB-DL8lA
Perhaps it helps to configure the "place" the Shelly is installed.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
49 People are following this question.
