lambertkleinjans avatar image
lambertkleinjans asked
MPPT 100/20 very low voltage
My MPPT 100/20 suddenly only sees less than 1v on the battery. I’ve checked all connections. The wires into the MPPT when disconnected show a normal 12.2v, but once I connect this up the screws in the MPPT show a voltage of about 0.74V. The fuse is fine, the firmware is up to date. So not sure what to do here. Any ideas?
MPPT Controllersbattery charging
0.74V is shown by MPPT (in VictronConnect) or is measured by you with a multimeter on MPPT battery terminals? Or both?
lambertkleinjans avatar image lambertkleinjans seb71 commented ·
Hi, thanks for asking. When double checking this i realised there was a weak connection on the negative wire which caused the voltage jump. This is now sorted.
