sander-kersten avatar image
sander-kersten asked
Connecting H terminal on victron multiplus
I want to Connect an external Switch to my multiplus I 3000 . In the Manual it says this is possible through H terminal, leaving the outside Switch on multiplus in on position. Connect left and Middle for "on" Connect right and Middle for "charge only". What connection should be made for off, it doesn't say this in manual.
Multiplus-IIMultiPlus Quattro Inverter Charger
4 comments
You need a three position switch, with a center off position.
sander-kersten avatar image sander-kersten klim8skeptic ♦ commented ·
And the Center off position than doesnt Connect any of the contacts in H terminal?
klim8skeptic avatar image klim8skeptic ♦ sander-kersten commented ·
correct.
Ok thank you I am confused because the Manual says to leave the outside Switch on the multiplus in on position.
nebulight avatar image
nebulight answered ·
On page 51 you can see the different connections:
H is the spot on the multi where you can install a remote switch.
sander-kersten answered ·
I know I need to Wire it to H terminal but how to Wire it to the on off on switch? It only talks about wiring for on position or Charger only position in the Manual.
