solarwizard avatar image
Where can I find info on BlueTooth programming the SmartBattery Protect?
Can BlueTooth be used to turn on and off loads in addition to battery voltage levels?
Battery Protect
Paul B avatar image
Paul B answered ·
No at this stage its limited to doing whats in the setting menu of the victron connect app
solarwizard answered ·
Thanks Paul. How do I learn what’s on that setting menu? I have not yet purchased the BlueTooh version of the Battery Protect. I’m trying to decide if it would be helpful
safiery avatar image
safiery answered ·
Switch to the demo library on the Victron connect app and select Smart BATTERY protect. You can play with the settings. The only thing the demo doesn’t reveal is the fixed voltage gap between the disconnect and reconnect voltages.
