jerrylcaldwell avatar image
jerrylcaldwell asked
When using the charge current control assistant is the charge amperage limited to 90 or can it be set to the max of 120 on a MultiPlus 3000/120/12
I am using charge current control" assistant to turn my charger on and off. I see any value above 90 amps goes red when entering the setting. I have 3 106 AH batteries so my max charge rate can be 120 amps. Am I limited to 90 amps when using the assistant?
multiplus ve.bus
kevgermany avatar image
kevgermany answered ·
In the basic multi settings is an input current limit which controls AC in. This may be too low.
5 comments
jerrylcaldwell avatar image jerrylcaldwell commented ·
My RV only has a 30 amp system so the AC input is limited to 30 amps. I normally have the dc charge amps set to 120 and it has never been a problem. I noticed any value above 90 in the charge current control" assistant shows red, so curious as to why.
kevgermany avatar image kevgermany ♦♦ jerrylcaldwell commented ·
Usually in VE configure, changed, but unsaved settings change to red. Saving moves them back to black. I'm not sure if this applies to your assistant.
I hope you're not going to pump 120A into 318Ah of lead acid.
jerrylcaldwell avatar image jerrylcaldwell kevgermany ♦♦ commented ·
No, 120A into 618AH of lithium iron phosphate. 40A for each 206AH battery.
Did saving do the trick?
Yes it did. Thanks for the input.
