ako avatar image
ako asked
I sensor 2 pieces of Equipment
Has anyone tried using one Temperature sensor to connect to an MPPT and a Multiplus . My MPPT is 1 mtr from the batteries and the Multiplus within 50cm of that so the insulation on the cable could be stripped away at the point it enters the MPPT then continue on to the Multiplus .
Temperature Sensor
Hi @AKO,
This will not work as the temperature sensor itself is at the end of the sensor cable.
sharpener avatar image
sharpener answered ·
Not a good idea. You will be connecting together the temperature sensing circuitry in the two different devices. I would not expect it to work and it might well cause damage.
kevgermany avatar image
kevgermany answered ·
This might help, depending on your setup.
https://www.victronenergy.com/blog/2018/03/22/voltage-temperature-sense-for-solar-chargers/
If you have a GX device, the standard multiplus temp sensor will be able to do what you want.
Victron temperature sensor disambiguation table - which product supports which sensor
