downgrader avatar image
downgrader asked
Initial Top Balancing Lifepo4 24v configuration
I have 4 SOK 12v 206ah batteries going into a 24v 412ah configuration to a Victron MP 3kw/24v
The SOKs have in-built BMS and have been sitting unused (in their shipping boxes) since late last year when I ordered them.
The voltage for each individual 12v battery is currently ~13.07 (two are at .07, one is .06 and one .08).
My question is what would be the best approach to do the initial load top balance? Should I use a bench charger device to bring each one up to proper voltage separately or will the Victron MP do the initial top balance correction even if they are in their ultimate 24v configuration? If the Victron MP will take care of it, are there settings I need to adjust from default for this to occur?
Lithium Batterymultiplus ve.busBattery Balancer
klim8skeptic avatar image
klim8skeptic answered ·
Sok recommend Notice for connect in series: If you need connect batteries in series, they should be at the same state-of-charge (SOC)before they are connected.
The only practical way to achieve this is to fully charge each battery (to top balance the cells inside) individually before wiring them in series.
downgrader avatar image downgrader commented ·
Thanks for the reply.
I read that if the batteries are within .05v of one another they're considered the same SOC and it's okay to wire in series. Any thoughts on this?
klim8skeptic avatar image klim8skeptic ♦ downgrader commented ·
I would still recommend that you have fully charged each battery.
2 Likes 2 ·
downgrader avatar image downgrader klim8skeptic ♦ commented ·
will do, thanks.
Battery Compatibility
