dragonzzr11 avatar image
dragonzzr11 asked
Smartsolar 100/20 app shows 0.2 volts less than actual battery voltage
As many already have pointed out in many questions, there is a voltage difference of about 0.2V - 0.1V between the reported app voltage and the controller terminals voltage.
Some report its higher, some report its lower.
In my case its reporting 0.2-0.1 V LOWER than the actual voltage of the battery.
The setup is as simple as it can get.
12v system
12v Lifepo4 battery->25cm 6mm2 cable->Smart Controller
Nothing else attached or connected.
Voltages have been measured both on the MPPT battery terminals as well as on the battery itself and i have confirmed it with three different multimeters.
Possibly a firmware problem or its just "acceptable", with all the side effects that it may have (like f.e terminating bulk stage 0.2v HIGHER in reality ?)
MPPT ControllersMPPT SmartSolarVictronConnect
Trevor Bird avatar image
Trevor Bird answered ·
I think we have to accept these small variations as an acceptable level of precision for these products. 0.1 or 0.2 of a volt is a pretty small variation.
dragonzzr11 answered ·
I agree to some point with your answer, but 1.5-2% accuracy variation is probably significant when charging/discharging LIFEPO4 batteries where tolerances are so tight.
I just cant understand why the app reports different voltage than the controller itself.
Anyone from Victron has an answer ?
MPPT Product Page
MPPT Error codes
VictronConnect Manual
Download for iOS / Android / Mac / Windows
