agarreau avatar image
agarreau asked
Output voltage of the LOAD Output on 75|10 controller
I read that the output voltage of the LOAD Output on a VictronEnergy MPPT Bluesolar 75|10 controller was the same as the output voltage of the battery. I plan a 12V Battery to the controller.
My question is : is the LOAD voltage output always 12V (as long as the battery is charged enough) or is it the same as the battery (which can vary between approximately 11V and 14V, depending on the mode) ?
Thank you for you answers !
MPPT Controllersvoltage
MPPT Product Page
MPPT Error codes
