i want to know if it is possible to wire the color CGX to a transformer 220v/12v rail ? instead of taking power on the batteries ?
Yes that will work, can't really see why you would do that. Maybe I misunderstand. Are you running you inverter from batteries to get 220v then transforming down to 12v to run the ccgx . ??
in fact,i need ton install the color in my house instead of my other batteries local.The distance is 20meter , i have a good quality ethernet cable for linking to the Multi and a transformer220v/12v is close to me to get the voltage to the color. That is why i wonder if i can use it , if not i need extend the stock wires to the batteries to 20 meters
Hi Ram. This isn't a direct answer to your question, but I'd encourage you to consider using that ethernet cable just for a remote and totally functional link to your CCGX, which you could then leave next to the Multi (and other kit you may decide to add in). Laptop/Pad/whatever.
8 People are following this question.
SMA STPTL-30 + data manager M + Victron Quattro = ESS + zero feed-in
Batteries apparently losing charge on light load
Quattro based SOC % counts down too slowly but CCGX displays correct AC load wattage
Can Color GX use Wifi for remote VRM comms and wired LAN for direct comms to SolarEdge HD Wave
After Firmwareupdate: Multi restarts all the time (after every ~10sec)
