scottd avatar image
scottd asked
New setup Cerbo Tanks sencers
Hello Everyone. Thanks for taking the time to read this.
I am designing a new setup using the Cerbo GX I have a question o nthe tank sesors. I am planning on buying these 52mm Boat Car Fuel Level Gauge 240-33 ohm fuel Level Gauge Sensor Sender Units https://www.ebay.com.au/itm/144265957551 but i wanted to confirm with the community that they will work. I.E I don't need the GX Tank 140 device. The Manual for the Cerbo GX section 2.10 states.
The tank level inputs are resistive and should be connected to a resistive tank sender. Victron does not supply tank senders. The built-in tank sensor connections do not support mA or 0-5V type sensors, this type will require additional accessories or replacement with a resistive type sensor.
Thanks so much for your time and advise.
cerbo gx
Kevin Windrem avatar image
Kevin Windrem answered ·
Those sensors should plug directly into the Cerbo tank inputs.
scottd avatar image scottd commented ·
Thank you Kevin.
