VRM portal cell voltage logging
As there is no available option to log cell voltages on the VRM (yet), would a workaround using a couple of DC METER object instances containing the to be logged cell voltages do the trick? One could use the custom widget in VRM to join the graphs of the 4 "sensors" over each other for the 4 cells.
Is there a better option to get cell logging working on vrm?
