Hi!
Just a few quick questions for those in the know.
1. Is it possible to feed in DC overvoltage into "AC in" with a Multiplus-II 24/3000/70-32 WITHOUT using an ESS assistant?
2. If no, is it possible to program an ESS assistant so it does not really do anything? (I have my own designed system in node-red doing everything it does except grid feed-in.)
3. If yes on Q1, can I turn on and off grid feed-in with ModBus address 65 and set limit with address 66 without the ESS assistant?
Regards,
MrHappy
